Ir para o conteúdo principal
Apple iPod Hi-Fi Batteries Replacement
O que você precisa
  1. Apple iPod Hi-Fi Batteries Replacement, Batteries: passo 1, imagem 1 %32
    • Put your coin in the battery lock on the back of the the Hi-Fi. Turn the coin to the left to release the battery panel.
    • Remove the battery panel with your hands.
    • You can also use a metal spudger or flathead screwdriver to open the battery lock instead of a coin.
  2. Apple iPod Hi-Fi Batteries Replacement: passo 2, imagem 1 %32
    • Remove the six D batteries from the device.
Conclusão
6 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S16-G1, Livingston Spring 2018 Membro de Cal Poly, Team S16-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G1
Membros da 5
Autoria de 16 guias
3 comentários
good day.  Does the column charge the batteries when it is plugged in?
pay4e4ek777 - Responder
Nope, the hifi will not charge any batteries that are installed.
Josh Calvetti -
Hello, I realize these comments/texts are a bit old (2019) however, I have an Apple Speaker unit from 2006 that is practically new with very little usage but stopped working due to purchasing a Bluetooth adaptor and inserting it in the rear (Audio in) jack. It had been working “great” with the Bluetooth and my iPhone for a while until the speaker unit ceased to function-turn back on (no power). Can you kindly assist in assessing-determining what might have gone wrong and what would be required to fix this problem. Many thanks ahead. Look forward to your reply.
Roosevelt Adrianza - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 24
Últimos 30 dias: 110
Duração total: 4,467
