Introdução
Step 1 Make sure your Iphone is turned on and unlocked
Step 2 Plug in your phone with a USB if you are using apple , If you are using Android make sure your blue tooth is turned on .
Step 3 Go into settings and connect your phone to the car .
Step 4 If you accidentally wipe the screen use a micro cloth , and you can use the scroller to scroll through radio stations and things on pone if your wipe the screen .
Step 5 If you music on your phone doesn't work restart the car and re plug in the USB or lighting cable back into your phone .
Step 6 If still doesn't work take the car back to the dealership
Step 7 It might be a computer malfunction
Step 8 It might be that you don't have a chord in the usb
Step 9 Car Play is only Iphones and with a cord
Step 10 Doesn't still doesn't work take back and explain to the dealer and the would replace it .
  1. Insert wisdom here.
    • Insert wisdom here.
Conclusão
Jonathan Loughran
73 reputação
Autoria de 1 guia
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Todo: 79
