Ir para o conteúdo principal
Apple Wireless Keyboard Logic Board Replacement
O que você precisa
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: passo 1, imagem 1 %32 Apple Wireless Keyboard Logic Board Replacement, Logic Board: passo 1, imagem 2 %32
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: passo 2, imagem 1 %32
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: passo 3, imagem 1 %32 Apple Wireless Keyboard Logic Board Replacement: passo 3, imagem 2 %32 Apple Wireless Keyboard Logic Board Replacement: passo 3, imagem 3 %32
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: passo 4, imagem 1 %32
    • Keeping the connection cable, push out the logic board's placement
  5. Apple Wireless Keyboard Logic Board Replacement: passo 5, imagem 1 %32
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: passo 6, imagem 1 %32
    • Remove the logic board from the placement
Conclusão
20 outras pessoas executaram este guia.
Nicola
Membro desde: 11/14/13
638 Reputação
Autoria de 1 guia
9Comentários do guia
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - Responder
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - Responder
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - Responder
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - Responder
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 92
Ao todo: 50,039
