Ir para o conteúdo principal
Apple Time Capsule Model A1254 Internal Power Supply Replacement
O que você precisa
  1. Apple Time Capsule Model A1254 Internal Power Supply Replacement, Back Plate: passo 1, imagem 1 %32 Apple Time Capsule Model A1254 Internal Power Supply Replacement, Back Plate: passo 1, imagem 2 %32 Apple Time Capsule Model A1254 Internal Power Supply Replacement, Back Plate: passo 1, imagem 3 %32
    • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
    • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
    • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
    • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
  2. Apple Time Capsule Model A1254 Internal Power Supply Replacement: passo 2, imagem 1 %32 Apple Time Capsule Model A1254 Internal Power Supply Replacement: passo 2, imagem 2 %32
    • Remove the ten 3mm screws with a Phillips #00 screwdriver.
    • The screws with adhesive covering do not need to be removed.
  3. Apple Time Capsule Model A1254 Internal Power Supply Replacement: passo 3, imagem 1 %32 Apple Time Capsule Model A1254 Internal Power Supply Replacement: passo 3, imagem 2 %32
    • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
    • Pull the base of the wire close to the logic board and the connector will pop off.
  4. Apple Time Capsule Model A1254 Internal Power Supply Replacement, Internal Power Supply Replacement: passo 4, imagem 1 %32 Apple Time Capsule Model A1254 Internal Power Supply Replacement, Internal Power Supply Replacement: passo 4, imagem 2 %32
    • Remove the external connector from its housing by lifting it up, then out.
    • Lift the internal power supply brick out of the device.
    • You may have to wiggle the brick slightly when removing it, but it will lift straight up and out as nothing else is holding it down.
  5. Apple Time Capsule Model A1254 Internal Power Supply Replacement: passo 5, imagem 1 %32
    • Disconnect the SATA connector from the hard drive.
    • This cable does not have a locking mechanism so it can just be pulled out.
  6. Apple Time Capsule Model A1254 Internal Power Supply Replacement: passo 6, imagem 1 %32
    • Disconnect the final power cable from the logic board.
    • Be careful when pushing in the tab on the logic board connector to release the cable lock.
Conclusão
15 outras pessoas executaram este guia.
Keaton Frahmann
Membro desde: 10/06/16
828 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-2, Livingston Fall 2016 Membro de Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
4 Membros
Autoria de 17 guias
5Comentários do guia
My time capsule stopped working. I tried everything but it was completely dead so I bought a new power supply on eBay but now the amber light is solid and won't turn green. I've tested the hard drive and it's fine. I've got another new power supply today and still a solid amber light. Any ideas please?
Andrew - Responder
After the Apple Reseller said the device was not covered by service anymore and data rescue would cost 70 bucks I decided to go for it myself. Went very well. Except the grey rubber backplate was ripping apart on removal. Must be because of the device getting so hot. Will fix it with some self-adhesive rubber mat from the crafts store.
Thanks for the guide!
Colin Schmid - Responder
Hello is HOT I took the rubber mat off and rise it with rubber foot for better circulation of air, it helps alot.
Fernando Ascanio - Responder
After the new power supply the TC does not connect to hard drive. Have a green light.
Bill Hines - Responder
I think my TC finally died, and this looks to be the problem. Is the only source for replacement power supplies finding salvaged ones on eBay, or does anybody know of a more reliable source?
Drew Cross - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 103
Ao todo: 12,318
