Ir para o conteúdo principal
Apple TV 4K Remote Logic Board Replacement
O que você precisa
  1. Apple TV 4K Remote Logic Board Replacement, Remote Logic Board: passo 1, imagem 1 %32
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Logic Board Replacement: passo 2, imagem 1 %32 Apple TV 4K Remote Logic Board Replacement: passo 2, imagem 2 %32
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Logic Board Replacement: passo 3, imagem 1 %32
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Logic Board Replacement: passo 4, imagem 1 %32 Apple TV 4K Remote Logic Board Replacement: passo 4, imagem 2 %32
    • Unlatch the connector that binds the touch screen and logic board.
    • Afterwards, use tweezers to detach the connector that binds the touch screen to the logic board.
  5. Apple TV 4K Remote Logic Board Replacement: passo 5, imagem 1 %32
    • Lift the face from the body of the remote.
  6. Apple TV 4K Remote Logic Board Replacement: passo 6, imagem 1 %32 Apple TV 4K Remote Logic Board Replacement: passo 6, imagem 2 %32
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  7. Apple TV 4K Remote Logic Board Replacement: passo 7, imagem 1 %32
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  8. Apple TV 4K Remote Logic Board Replacement: passo 8, imagem 1 %32
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
Conclusão
Uma outra pessoa concluiu este guia.
Keenan Barber
Membro desde: 10/04/18
1.120 Reputação
Autoria de 3 guias
Equipe
UW Stout, Team S6-G3, Ogden Fall 2018 Membro de UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
Membros da 4
Autoria de 10 guias
Um comentário
Have you ever successfully reconnected the ribbon cable after disassembly? It seems nearly impossible to do by hand…
B R - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 24
Últimos 30 dias: 71
Duração total: 3,668
