Ir para o conteúdo principal
Apple TV 4K Remote Battery/Charging Port Replacement
O que você precisa
  1. Apple TV 4K Remote Battery/Charging Port Replacement, Remote Battery, Charging Port: passo 1, imagem 1 %32
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Battery/Charging Port Replacement: passo 2, imagem 1 %32 Apple TV 4K Remote Battery/Charging Port Replacement: passo 2, imagem 2 %32
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Battery/Charging Port Replacement: passo 3, imagem 1 %32
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Battery/Charging Port Replacement: passo 4, imagem 1 %32
    • Unlatch the connector that binds the touch screen and logic board.
  5. Apple TV 4K Remote Battery/Charging Port Replacement: passo 5, imagem 1 %32
    • Use tweezers to pull off the connector that binds the touch screen to the logic board.
  6. Apple TV 4K Remote Battery/Charging Port Replacement: passo 6, imagem 1 %32
    • Lift the face from the body of the remote.
  7. Apple TV 4K Remote Battery/Charging Port Replacement: passo 7, imagem 1 %32 Apple TV 4K Remote Battery/Charging Port Replacement: passo 7, imagem 2 %32
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  8. Apple TV 4K Remote Battery/Charging Port Replacement: passo 8, imagem 1 %32
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  9. Apple TV 4K Remote Battery/Charging Port Replacement: passo 9, imagem 1 %32
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
  10. Apple TV 4K Remote Battery/Charging Port Replacement: passo 10, imagem 1 %32 Apple TV 4K Remote Battery/Charging Port Replacement: passo 10, imagem 2 %32
    • Gently dislodge the battery from the remote case, making sure to avoid damaging the battery itself.
    • The battery should be fully removed now.
Conclusão
17 outras pessoas executaram este guia.
Keenan Barber
Membro desde: 10/04/18
1.120 Reputação
Autoria de 3 guias
Equipe
UW Stout, Team S6-G3, Ogden Fall 2018 Membro de UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
Membros da 4
Autoria de 10 guias
6 comentários
Great but can you explain how and what to use to seal it back.
With out sealing it not working properly
Thanks
Iva Sh - Responder
Hi there, where can you buy the actual battery replacement?… any links?
RLinhares - Responder
I second this. It would be great if someone could link us on where to buy the battery/charger replacement.
_ Dubb -
You won’t be able to source the original battery as it is spot welded to the lightning port cable and mobo cable, and is one unit. However if you can solder I have successfully replaced two remote batteries for about $6-$8 a battery.
sinkproductions -
I’ve searched high and low for this battery as mine will not maintain a charge for more than a few hours. I found this one for a Huawei watch: https://www.batteryclub.org/Goods/ECN106... that appears to be the correct specs, but I’m not sure it can be connected.
That noted, a new remote is only $52 and this battery is $39.50 plus shipping! So for my money a new remote is a better option since we know it will work, and it’s just $12 or so more! Nuts!
pgrobin - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 34
Últimos 7 dias: 289
Últimos 30 dias: 1,529
Duração total: 70,273
