Ir para o conteúdo principal
Apple TV 4K Logic Board Replacement
O que você precisa
  1. Apple TV 4K Logic Board Replacement, Logic Board: passo 1, imagem 1 %32
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Logic Board Replacement: passo 2, imagem 1 %32 Apple TV 4K Logic Board Replacement: passo 2, imagem 2 %32
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Logic Board Replacement: passo 3, imagem 1 %32 Apple TV 4K Logic Board Replacement: passo 3, imagem 2 %32
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: passo 4, imagem 1 %32
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: passo 5, imagem 1 %32 Apple TV 4K Logic Board Replacement: passo 5, imagem 2 %32 Apple TV 4K Logic Board Replacement: passo 5, imagem 3 %32
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
Conclusão
8 outras pessoas executaram este guia.
Keenan Barber
Membro desde: 10/04/18
1.120 Reputação
Autoria de 3 guias
Equipe
UW Stout, Team S6-G3, Ogden Fall 2018 Membro de UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
Membros da 4
Autoria de 10 guias
8 comentários
Where does one get a new logic board??
MP94025 - Responder
Any idea on where I can purchase. new logic board?
tylerchumchal - Responder
Where do you buy the board…….
Andy Grichtmeier - Responder
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - Responder
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 121
Duração total: 7,189
