Introdução
For many reasons this part may become damaged or you may need to remove it to access the inside. This Guide demonstrates how to do so.
O que você precisa
As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
To reassemble the device, firmly press the cover into place until it clicks. The apple logo should have its bottom facing towards the ports.
4 outras pessoas executaram este guia.
