Ir para o conteúdo principal
Apple TV 3rd Generation Power Supply Replacement
O que você precisa
  1. Apple TV 3rd Generation Power Supply Replacement, Snap-on Base: passo 1, imagem 1 %32
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
    Pergunte ao FixBot
  2. Apple TV 3rd Generation Power Supply Replacement: passo 2, imagem 1 %32
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
    Pergunte ao FixBot
  3. Apple TV 3rd Generation Power Supply Replacement, Logic Board: passo 3, imagem 1 %32
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
    Pergunte ao FixBot
  4. Apple TV 3rd Generation Power Supply Replacement: passo 4, imagem 1 %32 Apple TV 3rd Generation Power Supply Replacement: passo 4, imagem 2 %32
    • Disconnect the power supply connector from the logic board with a spudger.
    Pergunte ao FixBot
  5. Apple TV 3rd Generation Power Supply Replacement, Power Supply: passo 5, imagem 1 %32 Apple TV 3rd Generation Power Supply Replacement, Power Supply: passo 5, imagem 2 %32
    • Before you remove completely the power supply, unscrew the T6 screws on each side of the socket.
    • You may now be able to remove the power supply with a spudger.
    • Do not pull the wires to remove the power supply. The connector is fragile.
    • The rating of the power supply is 3.4V at 1.75A, which is identical to the 2nd Gen Apple TV's 5.95 watts.
    Pergunte ao FixBot
Conclusão
14 outras pessoas executaram este guia.
Vincent Monteil
Membro desde: 07/06/13
7.031 Reputação
Autoria de 19 guias
11Comentários do guia
you forgot to add the power supply is held by 2 tiny torx screw
morpheuse - Responder Compartilhar
Successfully sourced a new power supply for our 3rd generation after the last one was destroyed ironically by Apple juice. Sourced from China and replaced- presto!! It's working- all for $14.95
rcbakes30 - Responder Compartilhar
Where? I need on badly! Can you send me / Post here a link?
jakesterage - Responder Compartilhar
please, and where could be find the part, the power supply for AppleTV 3rd generation?
foxy72 - Responder Compartilhar
Hi, i have a 3rd gen Apple TV and I have problems with it, it doesn't turn on I don't now if it's the power supply or it is &&^&@@ up how can I figure out if it is the power supply and in that case where can I found one
ilichcorcegatreep - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 106
Ao todo: 21,258
