Ir para o conteúdo principal
Apple TV 3rd Generation Logic Board Replacement
O que você precisa
  1. Apple TV 3rd Generation Logic Board Replacement, Snap-on Base: passo 1, imagem 1 %32
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
    where so i find a new base to replace it with
    sharpeEZz - Responder
  2. Apple TV 3rd Generation Logic Board Replacement: passo 2, imagem 1 %32
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Logic Board Replacement, Logic Board: passo 3, imagem 1 %32
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Logic Board Replacement: passo 4, imagem 1 %32 Apple TV 3rd Generation Logic Board Replacement: passo 4, imagem 2 %32
    • Disconnect the power supply connector from the logic board with a spudger.
Conclusão
10 outras pessoas executaram este guia.
Vincent Monteil
Membro desde: 07/06/13
6.975 Reputação
Autoria de 19 guias
4 comentários
Where can I find a 3rd Generation Apple TV Logic Board?
Ricky Vaughn - Responder
Good question! Did you manage to find a replacement?
Nathan Bugeja -
Hi my wifi and athernet is not working in apple tv on screen it showing your apple tv is connected to local network its not connect to internet now how should i repair this
Mohamed Iqbal Sayyed - Responder
Mine too, where could I find a logic board replacement???
Juan Ignacio Gutierrez I. -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 27
Duração total: 9,685
