Ir para o conteúdo principal
Apple TV 2nd Generation Power Supply Replacement
O que você precisa
    • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
    • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
    • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
    • Remember, there are also screws hidden underneath the thermal pad.
    • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
    • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
    • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
    • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  1. Apple TV 2nd Generation Power Supply Replacement: passo 4, imagem 1 %32 Apple TV 2nd Generation Power Supply Replacement: passo 4, imagem 2 %32
    • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
    • Place the replacement power supply in the now empty spot.
Conclusão
Uma outra pessoa concluiu este guia.
Deanna Rice
Membro desde: 09/28/17
261 Reputação
Autoria de 2 guias
Equipe
2 comentários
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - Responder
My power supply of apple tv 2nd gen is damaged, it is not available?
Ceporce - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,658
