Ir para o conteúdo principal
Apple TV 1st Generation Power Supply Replacement
O que você precisa
  1. Apple TV 1st Generation Power Supply Replacement, Lower Case: passo 1, imagem 1 %32
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • The rubber base can tear if the adhesive hasn't been softened enough.
    • Repeat the procedure described above until the rubber base has been completely removed.
  2. Apple TV 1st Generation Power Supply Replacement: passo 2, imagem 1 %32
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
  3. Apple TV 1st Generation Power Supply Replacement: passo 3, imagem 1 %32
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
  4. Apple TV 1st Generation Power Supply Replacement: passo 4, imagem 1 %32 Apple TV 1st Generation Power Supply Replacement: passo 4, imagem 2 %32
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
  5. Apple TV 1st Generation Power Supply Replacement, AirPort Card: passo 5, imagem 1 %32
    • Pry the AirPort antenna cables straight up from their sockets on the logic board.
  6. Apple TV 1st Generation Power Supply Replacement: passo 6, imagem 1 %32
    • Remove the single T8 Torx screw securing the AirPort card to the logic board.
  7. Apple TV 1st Generation Power Supply Replacement: passo 7, imagem 1 %32
    • Cautiously lift the AirPort card and pull it straight away. Slide it from its socket on the logic board.
  8. Apple TV 1st Generation Power Supply Replacement, Power Supply: passo 8, imagem 1 %32
    • Disconnect the power cable straight up from its socket on the logic board.
    • There is a release tab that must be pushed inwards in conjunction with pulling to release the power cable
    • Make sure to pull the connector straight up from its socket and not toward the face of the logic board.
  9. Apple TV 1st Generation Power Supply Replacement: passo 9, imagem 1 %32
    • Remove the following three screws securing the power supply to the upper case:
    • One 4.8 mm T8 Torx screw
    • Two 5.8 mm T8 Torx screws
  10. Apple TV 1st Generation Power Supply Replacement: passo 10, imagem 1 %32 Apple TV 1st Generation Power Supply Replacement: passo 10, imagem 2 %32
    • Use your finger to push and dislodge the AC power connector inwards, towards the power supply.
    • This should pop out easily.
  11. Apple TV 1st Generation Power Supply Replacement: passo 11, imagem 1 %32
    • Power supply remains.
Conclusão
Celerityblur
Membro desde: 10/29/09
154 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 18-5, Maness Fall 2009 Membro de Cal Poly, Team 18-5, Maness Fall 2009
CPSU-MANESS-F09S18G5
Membros da 5
Autoria de 6 guias
6 comentários
A couple of quick notes:
1. In Step 3, you lift the cover first from the opposite end shown.
2. Before assuming the problem is the power supply, try replacing the CR2032 3V lithium battery found in the photo for Step 6. If the battery has died, it can cause the unit not to power up. Replacing it is easier and cheaper than a new power supply. :-)
tandrewak - Responder
I think my battery is dead and your note says step 6 shows the battery. I don't see it?
LesKangas -
Good advice, that is the easiest thing to check in the process described.
Nevertheless, I'm afraid it was not my case since I had checked the power supply with the tester and it had given no signs of life. Thanks for sharing your experience!
Sergey Troshin - Responder
Thanks for the guide. Once you open the device it’s kind of self explanatory but I was glad to find this tutorial to know that the replacement was possible. In my case, my power board was fried (and I mean, fried. The fuse blew in the house with an awful smell coming from the ATV. When I opened it the inside of the power board was a black mess). I didn’t see the link with the airport card but I guess this was steps for another tutorial.
nessdufrat - Responder
My problem with my apple tv first generation is that it will not power up. When I do, an amber I get am amber light that blinks a couple of times and then shuts down. If I wait a couple of minutes and power it up again, the same thing happens. Is this an indication that the power supply needs to be replace or could it be something else?
David - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Duração total: 21,414
