Introdução
Replacing the panels of the apple display.
O que você precisa
Lay the display facing down with the stand away from you.
Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
Quase terminado!
Linha de Chegada
