Ir para o conteúdo principal
Apple Studio Display M7649 Logic Board Replacement
O que você precisa
  1. Apple Studio Display M7649 Logic Board Replacement, Stand: passo 1, imagem 1 %32 Apple Studio Display M7649 Logic Board Replacement, Stand: passo 1, imagem 2 %32
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Logic Board Replacement, Panels: passo 2, imagem 1 %32
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Logic Board Replacement: passo 3, imagem 1 %32
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Logic Board Replacement: passo 4, imagem 1 %32
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 Logic Board Replacement, Metal EMI Shield: passo 5, imagem 1 %32
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 Logic Board Replacement: passo 6, imagem 1 %32
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 Logic Board Replacement: passo 7, imagem 1 %32 Apple Studio Display M7649 Logic Board Replacement: passo 7, imagem 2 %32
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 Logic Board Replacement, Logic Board: passo 8, imagem 1 %32
    • Remove the four screws holding the logic board to the display
  9. Apple Studio Display M7649 Logic Board Replacement: passo 9, imagem 1 %32
    • Remove these seven cables connected to the logic board.
    • There is an extra connection that no cable plugs into. This connection is for Apple to test their logic boards
  10. Apple Studio Display M7649 Logic Board Replacement: passo 10, imagem 1 %32
    • Remove and replace the logic board.
Conclusão
Andrew Tsao
Membro desde: 01/19/10
186 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-20, Maness Winter 2010 Membro de Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Membros
Autoria de 23 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 5,199
