Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Apple Powerbook 5300 Keyboard Replacement
O que você precisa
  1. Apple Powerbook 5300 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Keyboard Replacement: passo 3, imagem 1 %32
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
Conclusão
Uma outra pessoa concluiu este guia.
Scott
Membro desde: 04/26/11
155 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 25-30, Garner Spring 2011 Membro de Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,545
