Introdução
How to remove and replace the monitor on the Apple Powerbook 5300
O que você precisa
Position the Powerbook towards you with the monitor closed.
Press the battery removal latch located on the right side of the front panel.
Gently slide the battery out.
Turn the laptop over and remove the three T8 torx screws from the bottom panel.
Remove the side panels by pulling up and towards the rear of the laptop.
Remove the two Torx #8 screws.
2 outras pessoas concluíram este guia.
