Ir para o conteúdo principal
Apple Powerbook 520/540 General Disassembly
O que você precisa
  1. Apple Powerbook 520/540 General Disassembly, Case: passo 1, imagem 1 %32 Apple Powerbook 520/540 General Disassembly, Case: passo 1, imagem 2 %32
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: passo 2, imagem 1 %32
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Apple Powerbook 520/540 General Disassembly: passo 3, imagem 1 %32
    • Remove top left and top right screws.
  4. Apple Powerbook 520/540 General Disassembly: passo 4, imagem 1 %32
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: passo 5, imagem 1 %32
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Apple Powerbook 520/540 General Disassembly: passo 6, imagem 1 %32
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: passo 7, imagem 1 %32 Apple Powerbook 520/540 General Disassembly: passo 7, imagem 2 %32 Apple Powerbook 520/540 General Disassembly: passo 7, imagem 3 %32
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
Conclusão
9 outras pessoas executaram este guia.
Mark McNeff
Membro desde: 04/20/11
497 Reputação
Autoria de 2 guias
2 comentários
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Responder
Thanks been trying to fix this for a long time
Luke - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 37
Duração total: 6,664
