Ir para o conteúdo principal
Apple Powerbook 520 Floppy Drive Replacement
O que você precisa
  1. Apple Powerbook 520 Floppy Drive Replacement, Floppy Drive: passo 1, imagem 1 %32
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Apple Powerbook 520 Floppy Drive Replacement: passo 2, imagem 1 %32
    • Remove the plastic panel at the bottom of the display.
  3. Apple Powerbook 520 Floppy Drive Replacement: passo 3, imagem 1 %32
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Apple Powerbook 520 Floppy Drive Replacement: passo 4, imagem 1 %32
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Apple Powerbook 520 Floppy Drive Replacement: passo 5, imagem 1 %32
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Apple Powerbook 520 Floppy Drive Replacement: passo 6, imagem 1 %32
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Apple Powerbook 520 Floppy Drive Replacement: passo 7, imagem 1 %32
    • Lift the defective floppy drive from the body of the computer.
  8. Apple Powerbook 520 Floppy Drive Replacement: passo 8, imagem 1 %32
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
Conclusão
Kevin Peters
Membro desde: 04/19/11
130 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 20-66, Walters Spring 2011 Membro de Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
Membros da 4
Autoria de 3 guias
Um comentário
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 2,755
