Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
There are several steps to be done before you will have access to the sound card. These steps include removing the keyboard, RAM, hard drive, and display.
O que você precisa
Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
Lift the heat shield up and toward you.
Locate the orange tab, which should be just left of the hard-drive.
You must disconnect this orange tab from the logic board to enable the next step.
It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
Remove the single black Torx screw from the modem.
Remove the black rectangle that is being held on by the one Torx screw.
