Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
Pull the keyboard ribbon vertically from the logic board to release connection.
Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
Lift the heat shield up and toward you.
Pull the PRAM battery cable vertically upward to disconnect it.
Remove the battery by pulling up and to the left.
Remove the two T8 Torx screws that attach the heat sink to the processor.
Remove the long silver Phillips #1 screw from the heat sink.
Lift up the heat sink unit from the left side and remove.
Lift the processor on the right side and pull directly up.
The RAM chips should be in the slots on the processor.
After removing the RAM, your laptop should now look like this.
Remove the single black Torx screw from the modem.
Remove the black rectangle that is being held on by the one Torx screw.
Using your fingers, lift the modem from the socket it is plugged into.
Disconnect the cable that is attached to the end of the modem to remove the modem.
