Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Before disassembling the mouse, first try scrubbing the mouse ball with a toothbrush and isopropyl alcohol. Be sure to get the bristles between the ball and the housing as this will help remove dirt and dust that is clogging the rollers inside.
You can also try blowing into the "ball hole" with a can of compressed air.
Begin by flipping the mouse over, as shown.
Remove the bottom panel by pushing the release latch down and to the left.
You may need to pry the edge of the bottom panel up in the indicated area.
Remove the batteries.
Insert spudger between button and outer white ring.
Twist the spudger to separate the ring from the body of the mouse. Work the spudger around the whole mouse until the ring is completely detached.
Undo two clips using a spudger.
Similarly, use the spudger to unhook two pivot points.
Disconnect both flex cables.
The second photo shows how far to pull the latches.
When reassembling the mouse, both cables should be inserted into the connectors contact-side-up.
Remove three Phillips #00 screws that attach the scrollball assembly to the upper shell.
Pry the white ball cover out of the black housing with a small flat-head screwdriver.
Remove the four rollers from the black housing with tweezers. They are held in place magnetically.
141 outras pessoas executaram este guia.
49 comentários
Confirmed: these instructions work just fine for the usb version. The ribbon cable connectors are positioned slightly differently, but otherwise, exactly the same process. My usb mighty mouse is now like brand new. Thanks.
thanks, it worked perfectly.
Great guide. I followed it and re-assembled my wireless mighty mouse, only problem though, now the ball only scrolls up. When I scroll up, down, left, or right, the page scrolls upwards in all cases. Any tips?
