Introdução
This guide will help you remove and replace your computers speaker, if speaker is not working properly or at all.
O que você precisa
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
5 outras pessoas executaram este guia.
