Ir para o conteúdo principal
Apple IIc Power Converter Replacement
O que você precisa
  1. Apple IIc Power Converter Replacement, Disassembling Apple IIc Cover: passo 1, imagem 1 %32 Apple IIc Power Converter Replacement, Disassembling Apple IIc Cover: passo 1, imagem 2 %32
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Power Converter Replacement: passo 2, imagem 1 %32 Apple IIc Power Converter Replacement: passo 2, imagem 2 %32
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Power Converter Replacement: passo 3, imagem 1 %32 Apple IIc Power Converter Replacement: passo 3, imagem 2 %32
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Power Converter Replacement: passo 4, imagem 1 %32 Apple IIc Power Converter Replacement: passo 4, imagem 2 %32
    • Lift the handle straight up to remove.
  5. Apple IIc Power Converter Replacement, Power Converter: passo 5, imagem 1 %32
    • Remove the two 7.7mm length Phillips screws that secure the power converter.
  6. Apple IIc Power Converter Replacement: passo 6, imagem 1 %32 Apple IIc Power Converter Replacement: passo 6, imagem 2 %32
    • Grab the back of the power supply and pull out while lifting up so that it will clear the other components.
    • The power supply can be difficult to remove so be careful not to bend or damage any nearby components while you pull out the power supply.
Conclusão
7 outras pessoas executaram este guia.
Josiah
Membro desde: 10/06/11
658 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 21-23, Maness Fall 2011 Membro de Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 71
Ao todo: 4,859
