Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Release the catch by pushing it in using a plastic opening tool.
Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
Carefully detach ribbon connector from floppy disk drive by pulling it out horizontally.
Unscrew the four 8.5 mm screws that attach the floppy drive cage. Two screws are located on the front and back of the cage.
Carefully lift the floppy drive cage straight up to remove it.
8 outras pessoas executaram este guia.
