Introdução
If your driver is malfunctioning or broken, this guide will show you how to replace your Apple IIc floppy Drive.
O que você precisa
Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
Carefully place device upside down to remove the four centered 21.1 mm screws that secure the floppy drive.
8 outras pessoas executaram este guia.
