Ir para o conteúdo principal
Apple Extended Keyboard A1243 Keys Replacement
Instruções em vídeo
Conclusão
tayola
Membro desde: 07/21/22
9.859 Reputação
Autoria de 44 guias
3Comentários do guia
Not helpful if one is trying to remove a key for cleaning, without damaging anything.
Moeskido - Responder
yeah, do you know how to remove the keys?
Jaide s -
insert a thin screwdriver under the lower edge and pry up gently until it snaps out of the retainer clip, then pry up gently on the upper edge.
You may be able to dislodge any small debris under the keys without fully removing the key if you just pry the bottom loose and blow underneath.
Rich Wiebe - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 24
Últimos 30 dias: 93
Ao todo: 7,196
