Introdução
If the base station is not sending out a signal, the Wi-Fi card may need to be replaced.
O que você precisa
First start by peeling off the outer rubbery covering on the bottom of the device.
Take the device out of the casing and orient it so that you can see the WiFi card.
3 outras pessoas executaram este guia.
