Ir para o conteúdo principal
Apple AirPort Extreme Model A1034 USB Port Replacement
O que você precisa
  1. Apple AirPort Extreme Model A1034 USB Port Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 USB Port Replacement: passo 2, imagem 1 %32
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 USB Port Replacement: passo 3, imagem 1 %32 Apple AirPort Extreme Model A1034 USB Port Replacement: passo 3, imagem 2 %32
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 USB Port Replacement: passo 4, imagem 1 %32
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 USB Port Replacement, Motherboard: passo 5, imagem 1 %32
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Apple AirPort Extreme Model A1034 USB Port Replacement: passo 6, imagem 1 %32
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Apple AirPort Extreme Model A1034 USB Port Replacement: passo 7, imagem 1 %32
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Apple AirPort Extreme Model A1034 USB Port Replacement: passo 8, imagem 1 %32 Apple AirPort Extreme Model A1034 USB Port Replacement: passo 8, imagem 2 %32
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
  9. Apple AirPort Extreme Model A1034 USB Port Replacement, USB Port: passo 9, imagem 1 %32 Apple AirPort Extreme Model A1034 USB Port Replacement, USB Port: passo 9, imagem 2 %32
Conclusão
Michael Garcia
Membro desde: 10/12/11
411 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-15, Regan Fall 2011 Membro de Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
Membros da 3
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 3,119
