Ir para o conteúdo principal
Apple AirPort Extreme Model A1034 Internet Card Replacement
O que você precisa
  1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Internet Card Replacement: passo 2, imagem 1 %32
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Internet Card Replacement: passo 3, imagem 1 %32 Apple AirPort Extreme Model A1034 Internet Card Replacement: passo 3, imagem 2 %32
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Internet Card Replacement: passo 4, imagem 1 %32
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Internet Card Replacement, Internet Card: passo 5, imagem 1 %32
    • Remove four 1mm phillips screws from the bottom.
  6. Apple AirPort Extreme Model A1034 Internet Card Replacement: passo 6, imagem 1 %32
    • Separate the top and bottom of the metal casing. You will now expose the motherboard and AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
Conclusão
3 outras pessoas executaram este guia.
Michael Garcia
Membro desde: 10/12/11
411 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-15, Regan Fall 2011 Membro de Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
Membros da 3
Autoria de 13 guias
Um comentário
Thank you so much for your guide! I was challenging myself to do it without cheating, but couldn't figure out how to release the bottom plastic layer from the main unit inside after I undid the 3 Torx screws. Thankfully you avoided me having to break the whole unit by showing where the central screw hidden beneath the S/N 3 barcode sticker was and that it was Philips not Torx, and I can now pinch the A1027 wifi card and use it in my G5, instead of relying on ageing ethernet! Bless you kind folks!
HumptyDumpty - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 5,176
