Ir para o conteúdo principal
Apple AirPort Extreme Model A1034 Antenna Replacement
O que você precisa
  1. Apple AirPort Extreme Model A1034 Antenna Replacement, Outer Case: passo 1, imagem 1 %32
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Antenna Replacement: passo 2, imagem 1 %32
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Antenna Replacement: passo 3, imagem 1 %32 Apple AirPort Extreme Model A1034 Antenna Replacement: passo 3, imagem 2 %32
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Antenna Replacement: passo 4, imagem 1 %32
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Antenna Replacement, Antenna: passo 5, imagem 1 %32
    • Remove the two 4mm phillips screws to remove antenna.
  6. Apple AirPort Extreme Model A1034 Antenna Replacement: passo 6, imagem 1 %32
    • The circuit board connected to the antenna is attached to the metal case with foam adhesive.
    • Gently peel or cut the foam holding the circuit board with a knife and remove it from the AirPort.
Conclusão
Uma outra pessoa concluiu este guia.
Michael Garcia
Membro desde: 10/12/11
411 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-15, Regan Fall 2011 Membro de Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
Membros da 3
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 4,668
