Introdução
This guide demonstrates how to remove and replace the battery of the device in the case of a dead or malfunctioning battery.
O que você precisa
Unscrew the two 2.70 mm Phillips #00 screws on the side of the tablet that has the buttons and the headphone jack (bottom side when holding upright).
Place the red wire tip on the positive terminal. Hold the solder strand so that it is touching the terminal and tip, and apply heat with the soldering iron until the two fuse together and produce a small amount of smoke.
Repeat the procedure for the black wire tip to the negative terminal.
4 outras pessoas executaram este guia.
