Introdução
Instructions on how to replace a damaged touchscreen display.
O que você precisa
Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
Remove the three screws that are located at the top of the circuit board with the screwdriver. (2.4 mm head, 3.9 mm in length)
Quase terminado!
Conclusão
