Ir para o conteúdo principal
Apex Digital DTV Converter Box Power supply Board replacement
O que você precisa
  1. Apex Digital DTV Converter Box Power supply Board replacement, Power Board: passo 1, imagem 1 %32
    • Unplug your device from the wall outlet.
  2. Apex Digital DTV Converter Box Power supply Board replacement: passo 2, imagem 1 %32
    • Remove the screws on the sides and rear. There are two on each side and four on the back.
    • Note: only remove the black ones (the silver ones stay for now). You should have removed eight identical screws by now.
  3. Apex Digital DTV Converter Box Power supply Board replacement: passo 3, imagem 1 %32
    • Lift the top cover up and toward you simultaneously. It shouldn't require very much force.
  4. Apex Digital DTV Converter Box Power supply Board replacement: passo 4, imagem 1 %32
    • Locate the power board inside the converter box.
    • Circled in red in the picture.
  5. Apex Digital DTV Converter Box Power supply Board replacement: passo 5, imagem 1 %32
    • Remove this plug
    • You will need to squeeze the locking lever to release it. don't pull too hard.
  6. Apex Digital DTV Converter Box Power supply Board replacement: passo 6, imagem 1 %32
    • Remove this plug from the main board. It is not detachable from the power board end.
    • Be gentle.
  7. Apex Digital DTV Converter Box Power supply Board replacement: passo 7, imagem 1 %32
    • Remove one last cable. This one leads to the front panel
    • Be gentle.
    • Circled in red
  8. Apex Digital DTV Converter Box Power supply Board replacement: passo 8, imagem 1 %32
    • Remove the power cord from its slot in the casing. This will make it easier to remove the power board.
    • Circled in blue
  9. Apex Digital DTV Converter Box Power supply Board replacement: passo 9, imagem 1 %32
    • Remove the four silver colored philips screws holding the power board in.
    • Marked in pink (eeww)
  10. Apex Digital DTV Converter Box Power supply Board replacement: passo 10, imagem 1 %32
    • Lift the power board out. Be careful to not touch the bottom of the power board. even when unplugged, it may still hold a charge.
    • Here is the empty spot.
Conclusão
6 outras pessoas executaram este guia.
Michel
Membro desde: 06/18/10
288 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 9,002
