Ir para o conteúdo principal
Antique Singer sewing machine 1935 Thread adjustable guide Replacement
  1. Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Missing thread guide: passo 1, imagem 1 %32
    • The machine is missing the thread guide as shown here. Otherwise, it is operational.
  2. Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Machining the elements: passo 2, imagem 1 %32 Antique Singer sewing machine 1935 Thread adjustable guide Replacement, Machining the elements: passo 2, imagem 2 %32
    • You will need a lathe to machine appropriately sized elements to replace the mechanism.
    • I used alumunium for the machined elements. Use high speed to obtain smooth surface as you need the thread to slide correctly.
    • The assembly may be done used an M5 screw and a cone spring as shown.
Conclusão
Michal Ruzek
Membro desde: 01/27/22
739 Reputação
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 245
