Ir para o conteúdo principal
Anne Pro 2 Keyboard Keycaps Replacement
O que você precisa
  1. Anne Pro 2 Keyboard Keycaps Replacement, Keycaps: passo 1, imagem 1 %32
    • Set the keyboard down on a flat surface. Make sure it is turned off and is not connected to a power source.
  2. Anne Pro 2 Keyboard Keycaps Replacement: passo 2, imagem 1 %32 Anne Pro 2 Keyboard Keycaps Replacement: passo 2, imagem 2 %32 Anne Pro 2 Keyboard Keycaps Replacement: passo 2, imagem 3 %32
    • Use the keycap remover to remove the key caps from left to right.
    • Remove the smaller keycaps first so the surrounding larger caps can be removed more easily.
  3. Anne Pro 2 Keyboard Keycaps Replacement: passo 3, imagem 1 %32 Anne Pro 2 Keyboard Keycaps Replacement: passo 3, imagem 2 %32
    • Use the compressed air to remove all dust and hair from the keyboard.
    • Focus on the red key switches to make sure all dust and hair are removed from inside.
  4. Anne Pro 2 Keyboard Keycaps Replacement: passo 4, imagem 1 %32
    • New replacement keycaps can be used here, but if you see no damage to older keycaps they can be re-used.
    • Use the keycap remover to set in the keycaps starting from the bottom to the top.
  5. Anne Pro 2 Keyboard Keycaps Replacement: passo 5, imagem 1 %32
    • Inspect the final product, making sure all keycaps are back in the right place and functioning.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Omar Sukkar
Membro desde: 11/24/20
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 1,987
