Ir para o conteúdo principal
Anne Pro 2 Case/Housing Replacement
O que você precisa
  1. Anne Pro 2 Case/Housing Replacement, Case/Housing: passo 1, imagem 1 %32 Anne Pro 2 Case/Housing Replacement, Case/Housing: passo 1, imagem 2 %32 Anne Pro 2 Case/Housing Replacement, Case/Housing: passo 1, imagem 3 %32
    • Unplug the Anne Pro 2 Keyboard.
    • Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
  2. Anne Pro 2 Case/Housing Replacement: passo 2, imagem 1 %32 Anne Pro 2 Case/Housing Replacement: passo 2, imagem 2 %32
    • Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
  3. Anne Pro 2 Case/Housing Replacement: passo 3, imagem 1 %32 Anne Pro 2 Case/Housing Replacement: passo 3, imagem 2 %32
    • Using a Torx T5 bit, remove the five screws from the keyboard.
  4. Anne Pro 2 Case/Housing Replacement: passo 4, imagem 1 %32 Anne Pro 2 Case/Housing Replacement: passo 4, imagem 2 %32
    • Lift the keyboard slowly from the bottom side.
    • Do not fully lift the PCB because the battery is still plugged in.
  5. Anne Pro 2 Case/Housing Replacement: passo 5, imagem 1 %32 Anne Pro 2 Case/Housing Replacement: passo 5, imagem 2 %32
    • Gently unplug the battery connector by wiggling it back and forth.
  6. Anne Pro 2 Case/Housing Replacement: passo 6, imagem 1 %32 Anne Pro 2 Case/Housing Replacement: passo 6, imagem 2 %32
    • Remove the PCB from the main case.
    • Gently lower the PCB into the Zero-Degree housing from the top side first.
    • Firmly press it in once you have lowered it.
  7. Anne Pro 2 Case/Housing Replacement: passo 7, imagem 1 %32 Anne Pro 2 Case/Housing Replacement: passo 7, imagem 2 %32
    • Screw the five T5 Torx screws back into place.
  8. Anne Pro 2 Case/Housing Replacement: passo 8, imagem 1 %32 Anne Pro 2 Case/Housing Replacement: passo 8, imagem 2 %32
    • Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
    • Firmly press them in, ensuring they are flush with the rest of the keys.
Conclusão
3 outras pessoas executaram este guia.
Mohamed
Membro desde: 09/15/20
223 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here-   https://www.techtoreview.com/top-picks/a...
Abhinav Pal - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 74
Ao todo: 11,790
