Ir para o conteúdo principal
Anki Vector Belts Replacement
  1. Anki Vector Belts Replacement, Belts: passo 1, imagem 1 %32
    • Raise Vector's arms above his head.
  2. Anki Vector Belts Replacement: passo 2, imagem 1 %32 Anki Vector Belts Replacement: passo 2, imagem 2 %32
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
Conclusão
Uma outra pessoa concluiu este guia.
Shay Takei
Membro desde: 04/16/19
1.570 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S2-G6, Maness Spring 2019 Membro de Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
Membros da 4
Autoria de 10 guias
Um comentário
Anki statement on the consumer robotics company shutting down. ... Vector also used the cloud to get smarter over time via machine learning, Anki said. Customers on Anki Developers Forum are reporting that Vector is still alive and well. Of course, this could all change over time, which is exactly what we saw with Jibo.
PrestoStore - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 1,186
