Introdução
This guide will show you how to replace the motherboard in your Anker Soundcore Space Q45 headphones. You will need to remove the outer casing of the right headphone to access the motherboard.
O que você precisa
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
Remove two screws from the motherboard with a Phillips screwdriver.
Remove the motherboard from the headphones.
Uma outra pessoa concluiu este guia.
