Introdução
Are your Anker Soundcore Space Q45 ear cushions old or damaged, preventing you from using the device to its full capability? If so, here is a guide to fix the problem. All you will need is an iFixit Opening Tool to separate the cushions from the plastic clips.
O que você precisa
Insert an iFixit opening tool in between the cushion and the plastic.
Detach six clips holding the cushions in place.
