Introdução
Is your Anker Soundcore Space Q45 battery not holding a charge like it used to, preventing you from using the device to its full capability? If so, here is a guide to fix the problem in a few simple steps. This guide will require you to remove the outer casing of the left headphone to access the battery.
O que você precisa
Use the iFixit opening tool to disconnect six clips holding the outer covering in place.
Uma outra pessoa concluiu este guia.
