Introdução
This guide will show you how to replace the headband on the Anker Soundcore Life Q30 Headphones. The headband is the plastic piece that runs along the top frame of the headphones. The headband can be damaged over time, so replacing it lets the user continue wearing them with the same level of comfort. During this process, it will be important to not disconnect or damage the wire that runs under the headband.
O que você precisa
Unscrew the two 9.5mm screws from the interior side of the headband using a Phillips #00 screwdriver.
You can attach your replacement headband. This will need to be glued into place. From here, follow these steps in reverse order to reassemble the device.
Uma outra pessoa concluiu este guia.
2 comentários
Hello, i need to do this procedure, but i need to know where to buy the headband to do so, can you help me?
me too! i need to buy in Brazil.
