Introdução
This guide will show how to replace the ear cushions on the Anker Soundcore Life Q30 Headphones. The ear cushions are what hold the headphones on your ear, but they can wear down quickly. You will not have to take any difficult steps following this process. Before beginning, make sure that your headphones are turned off and unplugged from their charger.
O que você precisa
Orient the headphones such that the headphone speakers are closest to you, and the headband is furthest from you.
Adjust the folding hinge to where the speakers are facing up.
Make sure you can easily reach the edge where the cushion connects to the rest of the headphones.
Using one hand, hold the right side of the headphones still.
Using your other hand, slide the plastic opening tool in the edge along the cushion.
Gently pry the cushion off using the plastic opening tool.
Set the right ear cushion aside and repeat this step for the left side of the headphones.
Uma outra pessoa concluiu este guia.
