Ir para o conteúdo principal
Anker 2.4G Wireless Mouse LED Replacement
O que você precisa
  1. Anker 2.4G Wireless Mouse LED Replacement, LED: passo 1, imagem 1 %32
    • Use a spudger to gently pry off the stickers to reveal the location of the four screws.
  2. Anker 2.4G Wireless Mouse LED Replacement: passo 2, imagem 1 %32
    • Remove the four screws to continue.
  3. Anker 2.4G Wireless Mouse LED Replacement: passo 3, imagem 1 %32 Anker 2.4G Wireless Mouse LED Replacement: passo 3, imagem 2 %32
    • Pry the center of the mouse apart using a spudger to separate the upper and lower housing of the boards.
  4. Anker 2.4G Wireless Mouse LED Replacement: passo 4, imagem 1 %32
    • Remove the wires from the white crimp headers. This will separate the upper and lower housing units of the mouse.
    • Pull as far up on the wire as possible, but be careful to avoid ripping the wires.
  5. Anker 2.4G Wireless Mouse LED Replacement: passo 5, imagem 1 %32 Anker 2.4G Wireless Mouse LED Replacement: passo 5, imagem 2 %32
    • Take the upper housing of the mouse and remove the two screws that hold the board in place.
  6. Anker 2.4G Wireless Mouse LED Replacement: passo 6, imagem 1 %32
    • Gently remove the circuit board from the mouse.
  7. Anker 2.4G Wireless Mouse LED Replacement: passo 7, imagem 1 %32
    • To remove the LED, flip the board over and desolder the wires.
    • Replace LED with a new LED and resolder into place.
Conclusão
Colin
Membro desde: 02/10/14
406 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-39, Maness Winter 2014 Membro de Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 2,873
