Ir para o conteúdo principal
Anker 2.4G Wireless Mouse Battery Replacement
O que você precisa
  1. Anker 2.4G Wireless Mouse Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the battery cover with a plastic opening tool, nylon spudger, or a fingernail.
  2. Anker 2.4G Wireless Mouse Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery with a finger nail or a nonmetal tool.
Conclusão
Uma outra pessoa concluiu este guia.
Vincent Lee
Membro desde: 01/23/14
361 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-39, Maness Winter 2014 Membro de Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
Membros da 4
Autoria de 16 guias
2 comentários
My Anker vertical wireless mouse uses 2 "AAA" batteries. It is Model TMI56G. Batteries are fresh. Dongle is new. The mouse worked fine with the dongle that was broken prior to the company sending me a replacement. The highest bar on the thumb side on the mouse comes on and glows red briefly when I turn the mouse on. There is no clear button on top of the mouse. I have Windows 10 and when I check my settings I keep getting an "ERROR CODE 10" FOR MY ANKER Mouse. My LOGITECH mouse works just fine when I plug into the same USB port. Could I have been sent the wrong dongle for my ANKER Mouse? Please advise.
Thank You,
Richard Johnson
mutantear@comcast.net
Rick Johnson - Responder
Any help would be appreciated. I need to return the LOGTECH mouse I'm now using to it's owner.
Thanks,
Rick
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 5,522
