Ir para o conteúdo principal
Andobil Easy Clip Car Mount Replacement
O que você precisa
  1. Andobil Easy Clip Car Mount Replacement, Car Mounting Clip: passo 1, imagem 1 %32
    • In this case, the plastic connecting to the metal spring failed and caused one of the clip arms to break off.
    • Be sure to remove any pieces of broken plastic before you begin the fix.
  2. Andobil Easy Clip Car Mount Replacement: passo 2, imagem 1 %32
    • Loosen the knob on the back of the phone holder.
    • Be sure to hold on to this knob as it will be integral to the rest of the fix.
  3. Andobil Easy Clip Car Mount Replacement: passo 3, imagem 1 %32 Andobil Easy Clip Car Mount Replacement: passo 3, imagem 2 %32
    • Once the knob is fully removed, the inside ball joint loosens up and can be moved around.
    • Remove the ball joint from the base of the phone holder.
  4. Andobil Easy Clip Car Mount Replacement: passo 4, imagem 1 %32
    • Remove the tightening knob and set the broken clip aside or toss it in the trash.
  5. Andobil Easy Clip Car Mount Replacement: passo 5, imagem 1 %32 Andobil Easy Clip Car Mount Replacement: passo 5, imagem 2 %32
    • Locate the replacement clip that comes with the Andobil Easy Clip Car Mount Kit.
    • Put Tightening Knob on top of the new ball-jointed clip.
  6. Andobil Easy Clip Car Mount Replacement: passo 6, imagem 1 %32
    • Insert the new clipping mechanism into the back of the phone holder.
  7. Andobil Easy Clip Car Mount Replacement: passo 7, imagem 1 %32
    • Open the Jaws using the knob on the top of the ball joint mechanism.
  8. Andobil Easy Clip Car Mount Replacement: passo 8, imagem 1 %32
    • Line up the jaws with the car vent and then use the knob on the bottom to close the jaws.
  9. Andobil Easy Clip Car Mount Replacement: passo 9, imagem 1 %32
    • Tighten the knob on the back of the phone holder once you have adjusted it to the correct angle.
  10. Andobil Easy Clip Car Mount Replacement: passo 10, imagem 1 %32
    • Once you've finished tightening the knob, you are finished! This is the finished Product!
Conclusão
Uma outra pessoa concluiu este guia.
Alexander Tavares
Membro desde: 03/24/21
205 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 17
Últimos 30 dias: 68
Duração total: 1,783
