Ir para o conteúdo principal
Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement
O que você precisa
  1. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: passo 1, imagem 1 %32 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: passo 1, imagem 2 %32 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Disconnect plug from electrical outlet.: passo 1, imagem 3 %32
    • Complete this step to reduce the risk of burns, fire, electric shock, or injury.
    • Turn the control on the trimmers to "off".
    • Remove the plug from the electrical outlet.
  2. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: passo 2, imagem 1 %32 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: passo 2, imagem 2 %32 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove two blade screws from top blade.: passo 2, imagem 3 %32
    • Remove the two blade screws from the top blade of the trimmer.
  3. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: passo 3, imagem 1 %32 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Lift top blade from the device.: passo 3, imagem 2 %32
    • Lift the top blade from the device.
    • The bottom blade is attached, but not secured, to the underside of the top blade.
  4. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: passo 4, imagem 1 %32 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Remove bottom blade from top blade.: passo 4, imagem 2 %32
    • Flip the top blade over.
    • Lift the bottom blade from the top blade.
  5. Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: passo 5, imagem 1 %32 Andis T Outliner Trimmer with T Blade Model G Top Blade Replacement, Clean and lubricate the device if necessary.: passo 5, imagem 2 %32
    • Clean or lubricate the device if necessary.
Conclusão
David Taylor
Membro desde: 10/08/14
151 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-34, Donnelly Fall 2014 Membro de USF Tampa, Team 1-34, Donnelly Fall 2014
USFT-DONNELLY-F14S1G34
1 Membro
Autoria de 2 guias
Um comentário
Trying to find out how to sharpen. Blades are so expensive. $ 24 per pack.
I cut my hair every two weeks. Then dull blades.
I'd invest in some type of sharpening tool. ( Not sand paper ).
rslau13@gmail.com
Map daddy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 46
Duração total: 6,825
