Ir para o conteúdo principal
American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement
O que você precisa
  1. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sandpaper disc: passo 1, imagem 1 %32
    • Before you begin, be sure that the sander is unplugged and powered off.
    • Carefully tilt the sander back and lay it down on its side, exposing the three sanding pads on the bottom.
  2. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 2, imagem 1 %32
    • Peel the hook-and-loop sandpaper disc off of the driver assembly.
  3. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the driver pad: passo 3, imagem 1 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the driver pad: passo 3, imagem 2 %32
    • Use a 3 mm hex key or driver bit to remove the six 11.9 mm-long screws securing the driver pad.
    • Remove the driver pad from the sanding disc.
  4. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc: passo 4, imagem 1 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc: passo 4, imagem 2 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc: passo 4, imagem 3 %32
    • Use a flathead screwdriver to pry off and remove the rubber plug in the center of the sanding disc.
  5. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 5, imagem 1 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 5, imagem 2 %32
    • Slide a thin 22 mm wrench underneath the sanding disc and clasp it onto the flat part of the motor driveshaft to keep the driveshaft from turning.
  6. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 6, imagem 1 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 6, imagem 2 %32
    • Use an 11 mm socket and socket wrench to remove the 16.5 mm-long bolt securing the sanding disc to the motor driveshaft.
    • Apply counter torque to the driveshaft wrench as you loosen the bolt to keep the sanding disc from spinning.
  7. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 7, imagem 1 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 7, imagem 2 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 7, imagem 3 %32
    • Take two pry bars and insert them underneath the sanding disc as close to the driveshaft as possible.
    • Apply pressure to the pry bars in opposite directions to carefully pry the sanding disc off of the driveshaft.
    • Remove the sanding disc from the floor sander.
  8. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc bearing: passo 8, imagem 1 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc bearing: passo 8, imagem 2 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement, Remove the sanding disc bearing: passo 8, imagem 3 %32
    • Use a pair of snap ring pliers to compress the retaining ring inside the driver and remove it from the sanding disc.
    • It may help to use a small flathead screwdriver to pry out the retaining ring as you remove it.
  9. American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 9, imagem 1 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 9, imagem 2 %32 American Sanders EZSand Orbital Sander 07163A 2017 Sanding Disc Replacement: passo 9, imagem 3 %32
    • Place a 15/16" socket inside the center of the sanding disc and use a mallet to tap the bearing out of the disc.
Conclusão
Craig Lloyd
Membro desde: 02/10/16
35.351 Reputação
Autoria de 82 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 60
Duração total: 1,797
