Ir para o conteúdo principal
Ambient Weather WS-1001-Wifi LCD Screen Replacement
O que você precisa
  1. Ambient Weather WS-1001-Wifi LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • First, you will need to remove all four M2x1-7 screws (7mm length) located on the back of the device. This should be done using a Phillips #1 screw driver.
  2. Ambient Weather WS-1001-Wifi LCD Screen Replacement: passo 2, imagem 1 %32
    • From the side of the device use the plastic opening tool to pry the gray front casing from the rear black casing.
    • The ribbon cable is attached inside so the two pieces will not come completely apart. See step 3.
  3. Ambient Weather WS-1001-Wifi LCD Screen Replacement: passo 3, imagem 1 %32
    • Using a plastic opening tool, carefully press the black bar towards the ribbon and away from the white bar in order to release it.
    • The ribbon cable should come out and be attached to the back of the LCD screen resulting in two separate pieces.
  4. Ambient Weather WS-1001-Wifi LCD Screen Replacement: passo 4, imagem 1 %32 Ambient Weather WS-1001-Wifi LCD Screen Replacement: passo 4, imagem 2 %32
    • Next, you need to remove the LCD screen from the front casing.
    • Push on the front of the LCD screen to pop it out as seen in picture 2.
Conclusão
Jeremiah Miskimen
Membro desde: 11/06/17
107 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G2, Harley Fall 2017 Membro de IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Membros
Autoria de 3 guias
2Comentários do guia
Pretty useless guide since this is all pretty self explanatory with no reference on where to get a replacement or even a part number
Jared Dykstra - Responder
Exactly right.
j drag -
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 484
