Ir para o conteúdo principal
Ambient Weather WS-1001-Wifi Battery Replacement
O que você precisa
  1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: passo 1, imagem 1 %32 Ambient Weather WS-1001-Wifi Battery Replacement, Battery: passo 1, imagem 2 %32
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Ambient Weather WS-1001-Wifi Battery Replacement: passo 2, imagem 1 %32
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Ambient Weather WS-1001-Wifi Battery Replacement: passo 3, imagem 1 %32 Ambient Weather WS-1001-Wifi Battery Replacement: passo 3, imagem 2 %32
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Ambient Weather WS-1001-Wifi Battery Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • The battery can then be popped out using precision tweezers and replaced with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
Taylor Whitaker
Membro desde: 11/06/17
122 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S1-G2, Harley Fall 2017 Membro de IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Membros
Autoria de 3 guias
1Comentário do guia
Hello. My screen is not working. And the electric cable is good.
C Kaagman - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 849
