Ir para o conteúdo principal
AmazonBasics BTV1 Motherboard Replacement
O que você precisa
  1. AmazonBasics BTV1 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 AmazonBasics BTV1 Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
    • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
  2. AmazonBasics BTV1 Motherboard Replacement: passo 2, imagem 1 %32 AmazonBasics BTV1 Motherboard Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
    • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
  3. AmazonBasics BTV1 Motherboard Replacement: passo 3, imagem 1 %32 AmazonBasics BTV1 Motherboard Replacement: passo 3, imagem 2 %32
    • Tilt the case downwards until the speakers fall out of their housings.
    • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
  4. AmazonBasics BTV1 Motherboard Replacement: passo 4, imagem 1 %32 AmazonBasics BTV1 Motherboard Replacement: passo 4, imagem 2 %32
    • Gently pull each plastic connector from the motherboard.
    • Take a note of which connector goes with each component for easy reassembly.
    • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
  5. AmazonBasics BTV1 Motherboard Replacement: passo 5, imagem 1 %32
    • Gently pull out the two ribbon connectors to disconnect the motherboard from the case.
Conclusão
Chris Shannon
Membro desde: 02/01/16
1.039 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 14-2, Lacy Spring 2016 Membro de USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 492
